During my early racing days we ran 75/85 lbs of pressure, using 40 wt racing oil, Checking the oil after every race showed some silver flaked of bearing material in the oil (we didn't Have a filter then), At the mit point of the season I put in the spare engine and checked the bearings of the race engine and found the bearings to be full of pock marks in the rod bearings ( floaties) The next year we broke a crank, wrecked a block, Took the pieces into the inspection lab at the Bullard foundry and their inspection said the crank was broken from clavation erosion due to excessive oil pressure. We then switched to 10/30 oil and never had any more bearing or crank failures/ Also switched to a full flow oil filter. I have the picture someplace of the crank failure. I've posted it several times.
Gramps
