johndee138
I just purchased a low hours French Flathead and have some questions about a number of particulars involved with putting this motor in my 36.
I have read the Tardel booklet on the subject and any ( sometimes confusing) info online.
What water pumps will work?
Flywheel/ clutch changes/mods needed?
full flow oil system preferred?
Special stud with O rings for the headbolt and the sources for same?
Can I hog off the governor boss on the back of the motor without total disassembly as long as I block off the passages well and clean up real good post hogging?
Will 59AB heads work and are they the ideal candidates or is there a better choice out there.
This is a complete motor, the heads are off for inspection(looks good too!)
Any ideas about a PCV setup?
I will be running an early 4bbl Rochester carb set up for me by Charlie Schwendler on an Offy intake.
My main concerns are reliability and economy,
All you experts out there, feel free to chime in please, I know there are many ways to do this, I just want to do it once.
