I'm back. Here's the plan. New French block with a new 3.75 crank, new 8ba rods. I've decided to follow Ron's advice and bore out to 3 5/16th for a 258 ci motor. Egge 3 ring pistons, standard size valves, adjustable lifters, I'm undecided between a 77B or Max 1 cam? Standard Navarro 59 AB heads with a Navarro super dual intake with Strombergs. All the usual internals along with a good balance job. Stock 59 AB flywheel. I'm sure I'm forgetting something but that's the basics. I've read all the literature I can find on the French block which leaves one a little confused as to port or not, rework the exhaust or leave it alone for a mild street motor. I'm sure there's various opinions on here and I invite them which will leave me open to suggestions from the experts. Thanks
