Harold Degand
Hello.
I’m working on the cooling system of my 1932 french flat powered and I have some questions.
Only the left side french head accept a temp sending unit, and I don’t want to remove the other one for drilling it. Using only one water gauge is risked.
The aluminium water outlets on the heads don’t have thermostat inside. Originally, both 2.28 diameter necks are drilled and threaded for a temp switch. The thermostat is located above. I’d like to replace those switches by temperature sending units.
I’d like to fit smaller necks to match with radiator inlets but with the same principe. But I don’t find something like this.
Also, there is 3 options for the rad.
Stock, not pressurized, top angled connections
Alu repo from Speedway, pressurized, stock diameter connections, top are straight
Chinese (ugly) alu repo, pressurized, 1 1/2 top connection.
Any help will be appreciated.
Second pic. Found on internet. This is exactly what I need
