Freeing stuck guides.
2tudors
Has any one got any tricks for pulling guides?example-heat miricle spray etc.This is on a running moter I want change the cam in...I broke the bottom off one:mad: and want to save the rest without damage.
Thanks Dave
If anyone has a method for rusty seized ones I would be curious as well.
Lift the valve spring retainer enough to remove the keepers. Generally the valve will lift also. Give it a tap and the keepers usually fall out. Then you can pull the valve out and knock the guide down to remove the horseshoe clip and pry the guide assembly out.
Sounds like a plan.I imagine I could put the broken back in the same way I guess.It's only missing the very bottom under grove.They are the tightest set I've ever taken out.After I make sure it is burr free of course.
Thanks FlatJack
