Frame welting
Mike/Nebraska
I am putting the body back on my 29 roadster and I have a question. Does the frame welting go all the way from the rear crossmember to the front of the frame. I guess I didn't remember my front fenders having anything under them, but it seems likely it would help with squeaks
I believe it goes from the front of the frame to the end of the running board splash apron which is attached to the frame...it stops right there.
Pluck
Those two fixed you up with good info. Glad to see you posting again. I am not going to be able to make the Freemont swapmeet, so one less person to compete with for the goodies. Might need to have you look out for afew small parts. Will send PM closer to mid Sept. Rod
Say do you fellas know if it's the same for a 31 coupe?
....I mean does frame welt stop @ rear of splash apron?:confused:
I think that the 30-31's ended in the same place in back, but went to the underside of the frame horns somewhat in front. I am sure someone will correct me if I am wrong. Rod
