Marty_in_Mesa
Marty,
The spring for the long gas tank bolt is the same as those for the radiator. You can adjust the tension on whatever spring you choose by tightening/loosening the nut on the bolts for the rear body-to-frame attachment. I suggest that the 'kiss' principle applies here.
DavidG,
While I agree, I thought the spring tension may make a difference. I would think there is enough tension to give but not bounce....
