The frames almost all sag in the area of the motor mounts and the first body mount, just behind the motor mounts. This becomes the fulcrum, or pivot point for the correction of the sag. If you look at an old play lot teeter-taught-er you will see the closer to the pivot point the lesser the movement.
Since the motor mounts are with rubber pad and plates, and not bolted solid they are relatively compliant to frame flex and excursions at that pivot or fulcrum point. If that point is made the fulcrum with blocking during straightening. then the very slight movement, even as you over-bend the ends to compensate for spring back, will be of little consequence. I'd really be more concerned about loosening the rearward body mounts, which are farthest from the bend fulcrum.
I've straightened two frames with the motor mounts bolted in place and it didn't cause any damage. I would think driving over a rough set of RR tracks or a big pothole, and the resultant front wishbone slamming would put far more load on the cast iron flywheel cover than the non-impact forces of frame straightening.
That all said, the best method of frame straightening involves SHRINKING the stretched under cord of the "C" section in addition to stretching the compressed top cord.
The advantage to leaving the motor mounts untouched while straightening is lateral deflection and twisting will be contained while you attempt to apply vertical excursions on a "[" section.
After straightening would be a good time to replace the motor mount rubbers, you need them anyway if the frame was bent, as the bolts likely cut into them long ago.
Now, if the frame is bent laterally (inward from the side) somewhere else due to previous collision history then all bets are off, best to unbolt both the engine and body mounts.
Your experience may vary! Expect to be playing with body block shimming to re-align the body panel seams and door closure after the frame is true.
