Cape Codder
I have removed my steering column to have a look internally/rebuild. Well in fact, in my mind, it definitely needs my attention but
that is not my question.
After the removal I checked the two mounting holes and discovered they are BOTH elongated. I have thought of a way to rectify
the situation and would like pros and cons to my two idea's.
First is to cut a piece of the frame, square/rectangle, around the two holes and of course the sector shaft hole. Make a piece
exactly what I cut out and weld it in.
Second is to cut a piece of material, square/rectangle, drill to match the existing frame and weld the two nuts to the material.
When the column is reinstalled and bolted to the material then weld the material to the side of the frame.
Third is to weld the holes shut and then re-drill the hole BUT I really don't think I would be able to do that effectively. So I think I
would leave that as a last resort.
Again, pros or cons!
Thanks,
Cape Codder
Thanks,
Cape Codder
