frame ID numbers
wildwilly
is there a way to get the frame id numbers with out removing the body. was told the frame was stamped on the top part.
yes you can on some body`s and depending on where they stamped the numbers ford was not uniform on where they stamped the frames, and how nice your frame is, I can read my A400 numbers by just taking out the floor board but the roadster I`m working on now the numbers are right next to the front cowl bolt, it is worth looking for it before you take your body off.
Check out my website. Go to Additional Studies then go to Letters, Numbers and Codes. There you will see some examples of the numbers stamped on the frame.
Pluck
