CajunCrawfish
Got the cab off the 42ford 1.5ton/"THE DADDYO": cab is solid with some bad welds that saved the cab, single large dent in front passenger fender from first owner to repair but all is well. Frame on the other hand???: swiss cheese on second c-channel inside the frame. It has to come out. How do I get a new replacement? or should I just box the frame and then put the cross braces back in. Any recomendations? I refuse to use replace the original frame for plane straight c-channels. I did call pg-adams a while back on another project but they will not match angles, simple straight c-channels. They will fab the braces/cross supports. All suggestions taken seriously.
Going to give ATFand ACETONE a chance at freeing my engine. Hope it works.
