My Old Tools
Greetings. I haven't posted much but have been reading for several years. I bought a 1951 F1 with a 8BA several years ago out of an estate. The engine appeared to be a new build, clean in and out with many new parts. The entire restoration looked good, but was unfinished as the builder/owner died. It wasn't his first build. I bought without a single wire in the truck, so have been building a wiring harness over time.
This is my first flathead. I finally got around to firing the engine recently. Had 50# oil pressure turning it over. Finally got the fuel pump (new) pumping and put a Holley pressure regulator at 2.5 PSI on it. Went through the Holley 94 and checked everything, fresh rebuild in there too. Has a Pertronix kit in the Loadamatic. It is 12v. It fires up and runs somewhat. I have a very rich condition, some back firing in the exhaust. Vacuum guage shows a steady 12 inches. I checked the power valve and no leaks. Checked the float level. Valves all appear to be opening and closing. I have read that the vacuum should be around 18 inches. Changing the idle mixture screws doesn't have much affect. Next step is checking the intake manifold for leaks. Not sure where to go on the rich fuel problem. Timing is set by ear for now. The only timing mark is the raised dot on the front pulley. It sounds somewhat like it might have a more radical cam than stock, but I really don't know what is inside.
