Found an engine
liquidplumber
New member
This was half buried in my back yard. Anything usable or should I scrap it. Any info would be appreciated. thanks
With a hunk missing on the block, I would scrap it and the transmission looks like it has severe corrosion. Unless I am not seeing something useable, I too say "Scrap It"
I see a water inlet, a possible mag ring core, posssible pedals, fan bracket, with a lot of luck a head. None of them worth much but too bad to see them gone forever.
Great yard art - plant flowers around it until somebody needs the parts.
To the scrapyard it will go. I am in eastern Mass. if anyone is interested in it.
Any idea how old this is? just curious. Thanks for the replies
I see a ring gear in the transmission, which means 1919 or newer if the transmission had not been changed. (that is when starters were first used by Ford)
