john mullen
I am installing new 4 ring pistons in a 8rt .080 over. Can I loose the bottom oil ring or is it needed for stability. I know friction is heat and want to have less if possable
Pistons designed for it definitely need it. Three ring pistons are available but are expensive in the smaller sizes. There are some cast 3-ring types above .125 oversize but none below that aren't forged to my knowledge.
Just leave the 4th ring off. It is an extra oil control ring and is redundant. It has no effect on skirt clearance, piston stability, etc. You and the engine will never notice the difference.
Why do Silvolite, Sealed Power Egge and others still make 4 ring pistons today??They are definitely not nos. Both sealed power,grant,hastings and perfect circle all still manufacture 4 ring sets for that 4 ring piston.You have to fill the groove with a ring.
The piston manufacturers make stock replacement pistons and adhere to the original design, because its easy and that's what the market expects or accepts. Doing anything better might require some real engineering. For example, Egge makes both the early 3-ring flat-top 221 pistons and the later 4-ring 221 domed pistons. Egge also makes cast 3-ring pistons but only in the larger overbores, +.125 and larger.
This is an interesting discussion.
The piston manufacturer decided that the design of the piston required 4 rings. If you know more about the design of the piston than the engineer that designed and tested the piston in the engine, then leave out the unnecessary rings.
If you have to ask the question, you should install all of the rings.
