FORD6: IDing 262 vs 223
anteek
A friend wants to build a 262 to replace the 223 in his F-100. What is a quick way to identify one in a engine pile?
I could tell ya the difference between a 215 and a 223, but not familiar with the 262. But there are a lot of guys that mess around with all three of them at www.fordsix.com.
look in the board index under vintage Ford sixes
Dave,thanks for the tip but they don't cover this series. This is really outmoded information. thanks for trying.
This is info from Google you probably already have. 262s were offered 1961-1964. Some references have them only in HD trucks and Industrial applications. Others say that the engine was offered as an option in pickups. Measurement of bore and stroke may end up being needed to get a positive ID. They seem to be a rarity.
The Ford Falcon Web Ring has a good comparitive description between 215, 223 and 262.
" 262 (4.3L):
1961-1964(7)
bore 3.718 X stroke 4.03
Gear driven cam, distributor in front right of block, '61 - 64(7) 8 bolts holding down valve cover, early/big truck models had a fuel pump driven by an eccentric on the timing gear, later models ('64) had the fuel pump driven by an eccentric on the cam, exhaust manifold didn’t have a heat riser as the carb used a water heated spacer.
Truck only motor ('61-4 C550 & C600 tilt cab trucks, F600 trucks, B600 busses, '64 light trucks), possible industrial applications
Found in DIVCO trucks as the "G" series motor to '65(?)
Door code- '61-'64: B
Additional 262 info (thanks to the inliners site):
- The Hollander exchange manual says the 262 was made from 1961 to 1964.It will replace a 215 or 223 by switching some parts depending what the motor is going into. 223 heads can be used on the 262,but different years use different temp. sending units. Also early 223 heads will have to have the head bolt holes in the head drilled out so the 1/2-inch head bolts can be used. Intakes interchange, as will exhaust manifolds, but check the header pipe size and location where it fits on the manifold. Rocker arms of all types interchange. Three types of connecting rods were used.1961 to 1963 had heavy-duty cranks (steel)? And 1964 had both light duty (cast?) cranks and heavy duty cranks same as 1961 to 1963.Oil pans should interchange, but may have a larger capacity or a different sump location. I would pickup a Ford master parts catalog for more information.
- The Jan 96 12 Port news has a brief article on the 3 heavy truck engines: Chevy 261, Ford 262, and Mopar 265. It mentions that the Ford has an extra massive cast rib on the left side above the oil pan; 3.72 bore and 4.03 stroke; and full low oil filtration."
It looks like one of the key ID differences is the 262 has 8 bolts holding down the valve cover, vs 2 for 223.
My uncle had a 3/4 ton pickup in about 63-64. It was slow as molases, but there was no limit to what it would pull. With those big head bolts, a turbo is a natural.
the 262 has a different rocker cover with a bracket of some kind welded on top.its been awile since i saw one.easy to spot.
