Ford Y Block Hollow Pushrods Cleaning
Maybe I should butt out but IF you would just listen to what others are trying to tell you for once you may reduce your heartburn and maybe learn something in the process instead of saying "Hey" and all of a sudden you act like you just figured it out regardless of what anyone else has already said.
Just my 1¢. Now you can start calling me names again... :eek:
Y-Blockhead, you are my hero. I was trying to come up with th words, and then I read what you said. I sure can't improve on that. Well said.
Just leave the thread like an orphan and it will go away buy itself .Answering it only keeps it alive.
R
y blockers
here are pic's of NAPA replacement pushrods.
the press in tops are cone shaped and
they have press in bottom ball ends.
my couple of replacement pushrods are just like these.
the old ones are beginning to look like solid ones to me.
i don't see any seams at top and bottom.
they have a funny feel weight wise, i don't know
what they're made of.
doesn't feel like solid steel.
have a nice day!
More than likely those push rods were replaced due to a few different problems , like a bent push rod or one that was worn for one reason or another .
I build and rebuild engines and have done many of them over the last 40 years !
Now listen to what I am going to say , "Oil does not go through the push rods because it's a solid lifter engine ! That means you don't need oil being pushed through a hollow push rod from the lifter to the rocker arms ." The hollow push rods were made for the Y block to save money , period .
The oil that gets to the rocker arms on a Y block come through the rocker shaft .
Now if you can't get it this way then do just like everyone else here does and BUY A DAMN Y BLOCK BOOK AND READ IT !
Just asking the damn same old questions all the time will get you the same damn answers !
Jim
Hey guy's here is where we are at with the poster and this thread time to shoot it. :D
Some don't quite get it!!!
master cylinder, there are holes in both ends and
pushrod is hollow.
it comes DOWN from the rockershaft & rocker.
like i just described earlier.
have a nice day!
"That means you don't need oil being pushed through a hollow push rod from the lifter to the rocker arms ."
Jim
Jim according to AAB the oil flows DOWN the inside of the push rod...
Yes oil will get splashed from the rockers and then drip down the push rods but I was referring to the one that is used in a flat tap engine .
That guy doesn't have a clue on what the hell he is doing , nor does he even take time to listen to people trying to help him .
Waste of time for all !
Jim
y blockers
staying on the subject here, the solid pushrods
feel like they're made out of some Ford alloy.
something between steel and cast iron.
i think that a lot of the model t castings were made
from some material that Ford came up with.
note: in post #8 i said i caught on to how these pushrods work.
have a nice day!
Can any of you guys explain how these Y Block pushrods get oil?
Thanks so much & have a nice day.
I couldn't help myself, Sorry
Jim
Any body that knows Y Blocks, especially the 50's ones, know that Ford never used tubular pushrods. They always used the skinny ones. Not sure about the 60's Y's.
y blockers
for anybody interested in rebuilding their
y block engine.
the pushrods come in solid and tubular.
Mummert has a nice picture of a solid
one cracked from fatigue.
the tubular do not carry the oil like on
later engines, they're just lighter.
i would say if you buy new ones, get the tubular and
make sure their the right length.
have a nice day!
Say, all american boy, where are you located? Maybe someone from The Barn could drop by and give you a hand, maybe show you how these Y blocks work.
'Say, all american boy, where are you located? Maybe someone from The Barn could drop by and give you a hand, maybe show you how these Y blocks work.'
Our 292 went bye-bye.
What are you talking about?
I haven't posted here in months.
Why would I want to see somebody in person about an engine that
isn't here?
isn't here?
Oops! Didn't notice that this was a five year old thread! Sorry!
