Ford Y Block Duraspark Ignition Conversion
all american boy
y blockers
i'm doing it the simplest way.
converting my O ring y block distributor
by putting Duraspark parts in my housing.
if somebody wants to put a Duraspark distributor
in a Y block that's the other way.
have a nice day!
That's a good link, looks like a bit more work than the pertronix. Have to look at my junk, I might have this stuff laying around. Mark
frankenstein/mark
the question mark is whether the Windsor distributor is
identical in all ways except the gear size.
one thing to check is the oil pump intermediate shaft
to see if it's 1/4" hex.
then next would be length of shaft.
basically if it's the same from o ring mounting point in block down to shaft.
ok, back to swapping Duraspark internals into a y block distributor case housing.
i think the breaker plate is the 'make or break' item.
they have to be interchangeable.
have a good one!
