I hauled home this ’34 BB a few months ago. Originally It was a Crestline, CA Fire truck so it was up in the steep mountains. It has vacuum power brakes. Everything aftermarket they added to this truck was crude. I scrapped the rear body, it was ugly. Not a very pretty fire truck. I found an original Ford stake bed but it’s for a short wheelbase truck. I went ahead and bought the bed in case I can’t find the correct longer bed; I can always lengthen the one I have or change out the frame to the 131” wheelbase frame. I also need more of the original metal stakes and any hardware for the bed and maybe a side rail that I could use to lengthen the bed I have. That original Ford’s bed side rails are a unique stamping and would be a hard to make pieces to lengthen it. I really need another piece of an original bed.
I’ve only had it a few months. I pulled the front sheet metal which is really nice. Had the front bumper chromed, bought two new front tires and four used ones. Bought the stake bed for it. Pulled the heads, water got down in the engine so its toast. Its not 1934 21 stud but a later one, maybe a ’36. I have a running ’37 21 stud I’m going to stick in it. I’m looking for a nice pair of the 1934, 40- casting number, cast iron heads to put on the ’37 engine to make it look like a 34 engine.
They stuck a piece of steel plate across the frame and bolted the PTO and the brake booster to it. The booster has a chain that puls on a lever on the mechanical brake's cross shaft which is little funky. Later tonight, I'll get you a photo of the intake. They welded a fitting to it for the vacuum hose . Looks like it has a vacuum check valve there on the fire wall. Usually they have vacuum reservoir tank and the check valve holds the vacuum in it. There could be one under there, I have not crawled around under it.
