Ford T tools & parts FS
Mark W.
Stockton Springs
Maine
Price
IN AD
Here we go again - also see my ad in the A section for other "stuff"
Picture 1:
5Z157 wrench is $20.00
3Z647 wrench is $20.00
3Z601 wrenches are $20.00 each (4 available)
5Z156 (one poorly marked – other two unmarked) square main bearing bolt wrenches are $20.00 each
Picture 2:
5Z325 swivel socket wrench is $45.00
5Z161 (unmarked) 11/16” T-wrench (the early wire wheel lug wrench) is SOLD
3Z617 valve reamer – would need sharpening to use, but rare to find a Ford one - SOLD
3Z602 (earlier style) valve spring tool is SOLD
3Z602 (later style) valve spring tool is $20.00
5Z319 (same as later style 3Z602) is SOLD
5Z591 large hex wrench – note tube handle is flattened at end and cracked - $50.00
Picture 3:
Early “lobster-claw” script pliers $40.00
Other script pliers are $25.00 each and have a few to choose from
Unmarked headlamp bulb pliers (I think these were made by KRW) $35.00
KD valve tool marked "Special" is $20
KD valve tool marked "Ford Type" is $25
Accessory switch cover “Yale” – as is $15.00
Good used 1915-1918 headlamp switch is $40.00
“Buckeye” jack handle/tire tool (somewhat twisted, and hammered on but hard to find) - SOLD
T Ford spark plug, box, or open-end wrenches $5.00 each – Many to choose from
T & A Ford Monkey Wrenches $10.00 each - Many to choose from
T Ford hubcap Wrenches $8.00 each - Many to choose from
Picture 4:
Car tire irons - early or late Model T style $15.00 each or $25.00 per pair
Ton-Truck tire irons (the flat spoons on the heavy bar stock are TT's) are $25 each (the hammered one is $15)
Pictures 5 & 6:
NOS Ford script front cross-member with all four corner brackets also NOS - SOLD
Picture 7:
3Z2034 or 5Z324 Band ratchets are $25.00 each
The Diamond brand Clincher iron is $35.00
NOS steering quadrant is $50.00
The pair of front axle Snubber strap brackets are $50.00
The complete early clutch shaft has a good hole in the arm and is $50.00
The “R” lettered pedal is $50
All prices are PLUS actual shipping from zip 04981 Maine. In many cases the small priority flat rate box will get most any of this stuff delivered in the states, and if you are interested in a package deal with any other tools I'd listed I can combine shipping there as well.
Please call 207-323-8994 with questions - leave a message and I will return it (I don't answer at work) - Or you can take your chances by replying here, using a PM thru this site, or e-mail thru the site, but calling is best... I will do my best to answer people in the order of their calls.
