thunderbirdesq
- City
- Bflo
- State
- NY
- Price
- in ad...
Welp, I just got hosed on a clist engine I bought. need to raise some more capital. DON'T POST ON THE AD, send me a pm. Shipping not included
possible trade items include:
-F1 pickup stuff
-yblock speed stuff
<<<GONE>>>Pair of '37-'41 Ford split bones, have a hole drilled for a spring perch in the tube, weld it up or use it. One has a small nick from the torch on the taper, will not affect use or even be seen when installed. $50
(((SOLD)))'40 ford complete rear axle. 3.78 gears, hyd brakes, 16" steelies (have some pitting, should clean up ok for a driver), nice spring, torque tube, driveshaft, and speedo turtle, spins nice, was removed to build a street rod
... $350 local pickup only on this.
(((SOLD)))Nice pair of roundback '37-41 Spindles, all threads are good, add your new kingpins and down the road you go. $175
Complete pair of '40 front brakes, loaded backing plates with shoes and cyls for cores or rebuild, all og ford mounting bolts and hardware, drums will need turned, hubs loaded with bearings nice and greasy, one lug stud has been welded to the hub on the backside, doesn't affect operation. $200
<<<SOLD!>>>Pair of '37 wide 5 front hubs/drums, need turned, but lots of meat left, nice greasy bearings inside. These WILL work with later juice backing plates. $150
Model A wishbone ball cup w/ original bolts, needs new rubber. $10
Home-made batwings, these came off some axle I bought for the brakes. They are ugly and would to be cleaned up or redone if you're picky. But the tapered bosses are nice. $25
tri-5 Chevy MC, made in the USA, most likely needs rebuiltbut isn't frozen. $30
'41 Ford dash trim, Bob Drake, THESE PIECES HAVE BEEN TRIMMED where they meet in the center to fit a '41 dash that was narrowed to fit my roadster. So if you have a early car with a narrowed '41 dash, these will be perfect. I paid $100 for this trim, cut it to fit and found some chrome aftermarket accessory trim the next week. DOH! $40
50's BOP brakes, looks like somone rebuilt these and just let them sit. Drums look freshly cut or new, braking surface is perfect, shoes are new. Wheel cyls probably need honed/rebuilt. You're buying a complete pair even though the pic only shows one assembly. $75
-F1 pickup stuff
-yblock speed stuff
