Ford steering shaft
Deuce Man
Palm City
Fl
I need a length of ford steering shaft with the taper and keyway, to graft on to a 37 hudson box I recenly found for my 32. It doesnt need to be much more than a foot long or so. Thanks, Rich
if you will fill me in on that cool cross member in that 29 frame, I will send you shaft piece that you need.
Flatmotor 40, the one speedway sells is a stepped straight shaft with a keyway for a T wheel. Plus no hole thru the center for the horn wire Thanks for thinking of me! Rich
