Marvin, its an ash frame clad in aluminium NO FIBRE!The chassis has been lowered by 4” and has extended front dum irons. It has also been modified to a longer wheel base. Model A Engine fitted with a Model B crank shaft
* Line bored shell bearings conversion to rods and mains
* Cross drilled crank shaft
* Lightened flywheel
* Fully balanced
* Mild camshaft
*Aluminium Cylinder head fitted – I.O.E type with 2” inlet valves
* Fully adjustable oil pressure relief
* Twin SU carbs
* 4 Branch balanced exhaust manifolds
* 2 ½” Exhaust System
* Mag Ignition
