How about a hint? Maybe a picture? The "81C" prefix says it was first used on the 1938 Commercial but it looks like there are too many digits in the rest of the number, are you sure it is correct? Where did you get the part number? On the box? Cast into the part? Stamped into the part?
Most of the really long numbers (if they are actual FoMoCo numbers) are in the body parts catalogs. My copy of the 1944 to 1952 body parts catalog lists a P/N 81C-811833-A as near what was mentioned before "Run and Clip Assy (Door Glass) Lock Side Lower. Being one digit different, then it is likely an oposite side to that part number.
My 1938 Body Parts List for pass. cars,commercial and truck lists P/N 81C-811834 as Run (front door glass)and clip assy.-hinge side -lower . It shows for the panel delivery model 820 & 920 and model 810 closed cab (cab over engine).
