steve fritz
- City
- onalaska
- State
- wisconsin
- Price
- $175
Nice clean , tested good, overdrive transmission solenoid from 1955 Ford 3 speed . Has part number 10AR108-62 on the cap. I opened up and inspected, all looks clean inside. I mended a couple spots on the original wiring with shrink-wrap. Tested and it works fine.
I also will include the fire wall mounted relay and gas pedal switch, along with original wiring. These parts are not tested and look like the relay will need rebuilding for sure, the switch may be good, don't know and the wiring is shot, can be used as a pattern for new harness.
