Calling all Ford Transmission experts, I don't know alot about transmissions and I've gone as far as Im comfortable going. Please excuse me if I'm not using the correct terminology.
I'm trying to get my '54 Country Squire on the road. and the transmission is being a problem. As far as I know it has the factory 239 yblock and fordomatic transmission.
When the car runs in Park it feels like it is under load. When you shift in to what's indicated as reverse, it acts like it is in park or neutral. When you shift in to drive it has good reverse. If I pull the shift lever all the way down it will go in to drive then kind of fall out of gear.
I checked the shifter and linkage and it looks ok so I dropped the pan to see if there's an internal linkage problem I can see. What I found is that the ball on the shifter that rides in the groove in the manual valve was in the incorrect position. I moved the manual valve with my finger and when it rotated it moved away from the linkage, almost as if either the valve is bent.
What should my next step be?
