Ford nut fitting question
mtd1960
Looking to find a fitting that ford nut fuel fitting goes in (female) to 1/8” pipe male. Making up a fuel line for a glass bowl filter. Thanks for the help in advance.
The easiest thing to do is just to buy a fuel line from one of the suppliers. If needed it can be modified by bending and/or adding a rubber hose section.
Isn’t that a standard 1/8” compression fitting? We’re talking about the outlet from the sediment bowl, right? But I agree, buy a steel fuel line from a Model A supplier and modify if you need to. Something like this? https://www.mcmaster.com/5220k61/
Use good quality fittings, not the crap that you get from the Big Orange Box or similar. That’s Class 1 flammable liquid you’re running through it!
What I am looking for is a fitting that one end is female compression 1/2-20 for “Ford nut” and the other end is male 1/8” pipe. Thanks
B-9288-FLA
Description: FORD FUEL LINE ADAPTER FITTING
Comments: 1/8"- 27 NPT male to 1/2"- 20 female ( for 1/4" tube nut & ferrule )
RENNER'S CORNER
Renner is the place.
I recently bought the Model B Distributor Rebuild Kit which he sells - and which includes all the do-dads that the usual Model A supplier neglects to sell.
I was pleased when he sent a follow up Email asking my satisfaction (which was perfect) and attached was not one but TWO "in depth look" at setting up a Model B Distributor.
How can you beat that?
Joe K
