Ford Museum (mostly) museum virtual tour
billjones
I posted this before (but not here) and received some great suggestions, here is the same tour but with a lot added, check out the turntable shots and all the new drivers POV panoramas. Most had trouble figuring out what to do so I created a tour map that should help get around. The panoramas will turn but it's not automatic, you have to turn the pano with the mouse or click on the circular icon. Have fun and give feedback. This is my resume to be submitted to museums, car, air and train. So feedback is very important to me.
I have also added more shots in the image galleries.
M work consist of developing virtual tours, I had the opportunity to do a excellent collection and just wanted to share with all. There are numerous way to navigate but to view interiors and the standard image galleries you need to use the drop down menu in the upper left.
http://rhmpano.com/tours/kenaustincars/
enjoy.
I can see I have visitors.
The problem I have is not knowing what you did out there. So it's hard to either anticipate what you want to look at, or if you did look at it.
Every car out there has it's own image gallery.
There are now 23 interior panoramas (drivers view). Use the tour map to get around.
One car is on a turntable and you watch it go around in circles, one revolution with the doors closed, one with everything open. That consisted of 192 separate shots.
So what did you see and what didn't you see, and if not, why not? All links work on my end, but maybe not yours.
If I don't know it's broke I can't fix it.
That's what I need to know
WOW!!!! That was a fun tour. It took me a bit (being computer challenged) to get my mouse slowed down so I wouldn't whiz by everything or go in circles viewing the ceiling.
I'll go back when I have more time to play and enjoy.
I get a black screen with a message in a box in the middle with words BLOCKED PLUG IN. I have never seen this block message before.
It works for me (Windows 7 PC with Firefox), and looks real nice. But the arrow keys and mouse are super-sensitive. Is there any way to make it react more slowly?
Doug
This works fine on my Mac, though it would be nice if I could slow down the movement a little bit. Maybe I can figure that out with a little more time on the site. Thanks for posting.
I thought it worked well. I was able to get right up on that neat little Austin.
A well lit and tidy shop is always nice to go through.
I need an ipad to track that done, to bad they don't support flash, although the tour is dual flash/html5
That was great. It worked fine on my mac, once I turned on flash. I usually keep flash turned off to eliminate all the blinking ads on some web sites.
That was great, thank you for posting, a few questions though..... Is that a real ARDUN head V8 or a mockup? And I couldn't read the sign about the 30's Lincoln, what year is it. I loved the 30 Roadster Pickup!
