Ford Model B pump question
shortyt
Guys I recently installed a B mechanical fuel pump on my B engine. My question is the lever that turns on the pump, is it supposed to be closed all the way or open? Is it a drain or a shutoff? Thanks!
It should have a small T shaped petcock.
It's not an on/off lever. That's there to drain the sediment bowl if necessary.
It must be closed for the pump to operate.
