norway
i got my gearbox, and engine back from overhaul this summer, engine had worn main bearing, and transmission had very worn bearing. today it was my first test run. it leaked oil, (but perhaps it finds its Level). and gearbox won't go into 2nd gir. sometimes i can og into 2nd gear, but that is rare.
engine is fresh overhauled With New babbit bearing, and much more, every worn part is swapped to one New. same With gearbox.
but gearbox shift Tower look like before, no New parts there. except that, everything is New in gearbox. everything is done by the same overhauler.
I only mounted the gearbox on the engine before I put it in the car.
before, 2nd gear worked ok.
thanks for help.
thanks for help.
