Ford model a knock
have not seen/heard vids
1. do what Bill said #3
2. then short out one plug at a time to see if anything changes
3. knock only at idle? Only on accel? only on decel? Please clarify
report back
when u short out a plug you take a long screwdriver and hold it between the top of the plug or the strap and the cyl head
The knock is pronounced enough that I would not start that motor again. A gasket set is cheap I'd open it up
Another timing gear test: Remove spark plugs and slowly turn engine over with the hand crank. If the gears are worn, there will be a distinct clack as the valve springs push the cam ahead of the crank (two valves at a time open, putting a load on the gears. Then two other valves close, and the springs pushing on the lobes push the cam ahead of the crank='clank'!)
All good suggestions.
I wish I had those suggestion back when I owned my first Model A.
The engine developed a rather large knock.
I never did figure out where the knock was coming from, but I finally had to replace the engine because it was using too much oil.
Neil
Tolson,
If you happen to have the starter off, see if the flywheel will rotate back & forth 1/8" or so. If so, the flywheel bolts are loose. This is a fairly common problem.
Bill Tight
It would studder a little at first and be completely fine after. Didn't smoke or anything just sounded awful. No clue what caused it. I'm assuming at one point the motor was stuck and a previous owner hit the top of it with a hammer since it gouges in it. The cylinder had no scrapes or anything in them
