SpencerM-EastTN
New member
Hello All,
I recently put a new engine in my recently purchased '30 Roadster.
The engine that I pulled from it was locked up solid and looked rough, so we decided that replacing the engine was the best route.
As my friend and I were cleaning up the garage to be able to walk through all the loose nuts, bolts, and wrenches...I noticed something.
The engine we pulled had "B97" on the head above the studs for the water pump and a small "Ford" script near the distributor hole.
Google says its a high-compression head, other sources say otherwise.There was no way to turn the motor and check the compression due to the condition of the motor. I haven't been able to check the combustion chamber to see if it has the traditional heart shape, which I plan on doing Monday (9/21) evening.
I just wanted to send this out to see if anyone has one of these or if there's any other information out there that I may have overlooked or not seen.
Thanks in advance,
Spencer
