I'm working on a friend's 34 Ford. I had the carb rebuilt. It runs very well but when you step on the brake easy or hard, about the same time the car stops the motor dies. Hit the starter and it restarts. I run the idle up fairly high( lot higher than it should be) and it helps but don't fix the problem.
What are we doing wrong?
