Ford Flathead pressure plate Bolt circle
Aulis Hameenkorpi
Have somebody info concern Ford Flathead pressure plate bolt patterns?.
Also interested in what is dimension between every two bolt pair.
I have Schiefer alum. flywheel and looks like its 10" or 11" pressure plate which match there. I do not have any pressure plate on stock , so I can´t fit. I have one 9 1/2" and that is too small.
I have Weber alum.flywheel in my Italmeccanica blower Flathead (59A) engine. I note that dimension between 2 bolt is bigger than normal flathead flywheel? What pressureplate I buy for that?
Rgds,
AULIS
PM or email: auliz@kotinet.com
Have you considered giving Ft Wayne a call? If you are going to run an aluminum flywheel I would think you would want to run the smallest diameter pressure plate and clutch you can get away with.
