- City
- Bristol
- State
- CT
I have 3 seperate Ford Flatheads for sale.
Motor One is an 8BA complete right down to the air cleaner sitting on the Ford 94 carb. It is attached to a 3 speed transmission. The stampings on the bellhousing are a D in the center with B802 to the right.
Motor Two is an 8BA Truck motor that was pulled from a 48 F-4 with 54,000 miles on it. It is complete and is bolted up to the 4 speed. truck transmission. It even has the speedometer cable and EBrake setup. It too has a 94 carb. The stampings on the bellhousing are a V in the center with G1994 to the right.
Motor Three is an EAB short blockwith heads and oil filter canister. The stampings on the bellhousing are 14 in the middle with J1324 to the right.
All of these motors being ford flatheads are curently stuck. They have been sitting in my garage for the past 20 years not out in the weather. The generators and carbs are not frozen up.
I would like $300 each for the complete motors with trannies and $100 for the shortblock with heads. Won't ship. I have pictures if you want to see them.
