ford convertible mystery windows
Can anyone identify the correct years for these windows. I believe they are for a cabriolet.
I believe they are but can not reference the dimensions. The 35 thru 38 Cabriolet windows are the same.
The front edge of the cabriolet door window is at an angle to match the angle of the A pillar. This window is likely for the rear door of a convertible sedan.
I just measured my window on my 1936 Cabriolet. The glass is installed in the door is about 12" high and the length at the longest is about 35 " Way off.
But yours and mine are the same style frames.
Definitely conv sedan rear window frame 1935 thru 1939
See glass drawings from Ford glass Cat 1937 thru 1944.
Here’s a pic of my front and rear 35 convertible sedan frames. It would appear your windows are from a cabriolet. Dan
Cabriolet's do not appear to have a vertical front frame but inclined. Here is a pic of a 35 CVS from DeAngeles book
My guess is that your window frames are 1940 Conv.
