Ford carbs for sale
packrat5
Sheboygan
Wi
Price
See ad
Here is a list of Ford carbs I have for sale. I may have more, don't know yet. NONE of them are what I consider junk, or for parts. I will consider offers on any of this stuff.
Holley list #8005, 600cfm emissions/performance carb. Earlier version of 80452. Rebuilt years ago on a clean low mileage carb, and never used.$175
Quick Fuel Slayer Series 600cfm with fuel line. Used very little, very low mileage, in almost new condition. An excellent performing street carb. Off one of our own cars. $250
Matching intake and correct #1273 Holley carb, spacer, and air cleaner for 1957 Ford 312. Restored to perfection, show quality. Lots of time, money and work went into this beauty. $700 Will separate.
1956 Ford 2-barrel 3-bolt carb. The last version of this carb, big bore, auto choke, great for center carb on tri-powers. Originally was used on 1956 272 engines only. Excellent rebuildable condition. $125 each have several.
Motorcraft 4350 carb rebuilt years ago, and never used. D8VE-GA originally Merc/Lincoln 460 carb. make offer
Holley list #4548 450cfm A very clean low mileage carb that has been SLIGHTLY modified. All parts included to return to original. Some extra stuff in original box included. Was used by brother on a Corvair Corsa setup. Again not a junker, or cob job, low mileage, very nice condition. $250
Motorcraft 4350 carbs, two of them. New. Still in the boxes. They appear to be AMC 360 carbs, but have not verified this for sure. Offers.
Motorcraft 2150 2-barrel carbs. 2 of them. 1.21 venturi. Same size as 350 cfm Holley, but no leaks, better mileage. One has port for active bowl vent, other does not. Both external vacuum brakes. Rebuilt to perfection, and look new. Improved power valves, and brass floats installed. These things work GREAT on older Mustangs, and y-block Fords, and look and fit like stock. $250 ea.
Carter AFB #2441 correct for 1957 Ford/Merc with 312 engine. Lots of TLC and parts used to restore this beauty to perfection. $300
Holley #1161-2 ECZ-H 4-barrel. Good rebuilder core. Choke housing assy. is missing. $125
Holley #1837 2-barrel manual choke. Crusty looking, but a rebuilder, or parts. $75
Motorcraft/Weber #D7EE-BBA 2-barrel for Mustang II/Pinto Good rebuilder $80
Motorcraft/Weber #D4ZE-DC 2-barrel for Mustang II/Pinto Good rebuilder $80
Holley #134-7S 59A-A 1-barrel Ford 6cyl carb. 41-51 Good rebuilder. $60
Motorcraft 2100 2-barrel carb. C5AF-B 1.14 venturi. Was some kind of factory rebuilt, rebuilder tag still on it. Very clean, could possibly be used as is without a rebuild. Pulled from one of our cars. $100
Motorcraft 2-barrel carb 2100 2-barrel 1.08 venturi no tag or id # would make a good rebuilder. $50
Here is an odd package I thought I would throw in. VERY nice Carter WCFB #3585 and Mallory dual-point tach drive distributor #YL356A for a Chris Craft 283 marine engine. This stuff is very nice. Anyone interested? Make an offer.
I have rebuilt carbs for MANY years, I have done 30 of them since last fall. I was a factory trained and certified Carter tech years ago. I work reasonable, and NO COB JOBS done here. I am available to rebuild your carb(s)
