Yes, it has been my recent experience (MARC San Diego) that the reproduction Ford battery available now, will be whacked 50%. I assume everyone with this battery was whacked the same way at that meet. I tried to detail the battery so that it would look closer to original, but the differences between it and an original battery are still evident, so you get whacked.
What I do not know is how much point whacking would be done if any other garden variety battery was used on a fine point car. If the only deduction would be the 50% for a reproduction item, maybe purchasing the Ford reproduction battery wouldn't make too much sense. That would be interesting to know.
I have been aggravated at times by this mindset too however when I sit back and analyze the system, I am not real sure just whom to point the finger at. It is VERY frustrating IMHO however that is the direction this level of adjudication has been heading for several years as evidenced by the Team Captain's score sheets. Their answer is a very valid one when they say that you need to restore to the best of your abilities and not make exceptions or excuses for deviating from originality. While sometimes I don't like to accept it, what they are doing is forcing me to raise my craftsmanship standards to join them, --and not the other way around!
Tim Johnstone was the team captain at San Diego and for those that don't know, I -like Ward, used a reproduction Ford script battery that I detailed the case by beadblasting it and making mould-markings on it where it looked very similar to an original ...however like his, it was/is obviously a reproduction due to the case size and a couple other minor details. In my mind, I knew it was a repro however I was hoping a Judge would notice the work I had done and give me some credit or leniency. In other words, if 10 points was the maximum and 50% (5 points) were to be taken off for a non-authentic item, I was hoping to receive a score of 7 or maybe 8 points for my efforts. I too received a 50% deduction just like others did who likely just installed it right out of the shipping box.
I have been on two different judging teams under Tim as the team captain and so I can testify that the man is absolutely fair when it comes to scoring however there is no leniency with the man either. It is either "real ...or repro."! If it is a reproduction, no matter how much work has gone into trying to camoflauge it to look "more authentic", it automatically receives a 50% point deduction when you are on his team. Now please don't misconstrue this that I am belittling him because he is extremely fair and by the book however he is a stern adjudicator when it comes to whatever area he is evaluating.
Another example is at San Diego where Tim was captain of Area 18 - Lighting. To show you how knowledgable and thorough this man is, I studied the chapter over & over prior to my arrival and felt I had a decent handle on what we were going to be looking at. When the team assembled, he had sheets that he had made for him to use that were timeline graphs for aiding us to visually inspect many little details. Many of these little details were things he had learned by studying factory blueprints. For example, on the headlight rims, the latch is attached by a tubular rivet. The rivet needs to be installed from the left (Driver's) side of the car and peened on the right side. While that information is not necessarily printed in the JS, it is on the prints. His point was not every detail can be outlined in the JS however that does not excuse something from not being required to be correct. Sure enough, out of the 15-20 fine-point cars there, I would venture 25%-30% of the cars had deductions for that.
The same for License Plate Clip hardware (on the headlight bar). In the
Standards on Page 18-2 in the 2nd paragrah, it basically states that ribbed clips that hung the plates below the bar were used until 5/1929 when the newly designed (non-ribbed) clips hung it above the bar. That's it!! On the Judging Sheets it has a line item that says License Clips and it refers you to Page 2 in that Area in the
Standards for guidance. There is 10 points assigned to that and as such, one could deduce that if you had the proper type clips (ribbed or non) mounted in the correct orientation on the bar, then you would likely be awarded the full 10 points. That is where "one" would be wrong!! Many of the cars that were there received a 50% point deduction if the clip fasteners were not correctly detailed. If you had one or all of them incorrect, it was automatically ½ off.
So how was an owner to know? In Tim's view, the owner should have used the Parts Price List and searched for A-13145 for the Clips, which would have shown the hardware was an A-20604 (Bolt), A-21668 (Nut), A-22166 (Washer), and A-22151 (Lockwasher). Then when you consult Mick Isbell's book regarding Fasteners & Finishes looking up those part numbers, you would have seen the Bolt was Black paint, the Nut was Raven finished, the Washer was Zinc plated (not Cad!), and the Lockwasher was unfinished.
So is this level of judging 'unfair'? Not really when you take time to read the entire "rule book". For example, on Page 3 of the
Standards in the lower left paragragh, it states "
The careful restorer and conscientious judge will supplement these standards by referring to the Ford body parts lists, Ford parts price lists, Ford service bulletins, Ford service letters, and Ford automotive hardware and trimming supplies books." Many people are unwilling to devote the time necessary to research all of the documentation available to us as restorers. I find it is very challenging almost to the point of being stressful but it is also very rewarding. Participating has definitely made me a better craftsman. Fine-point is definitely is not for everyone, and sadly many hobbyists will never understand even a small fraction of what is involved. And, the biggest thing I think most people don't understand is that it really does not cost as much to "authentically restore" as most people think. It does, however take effort and dilligence to execute a plan and then follow through with it as it was supposed to be, --and not how the restorer necessarily thinks it should be! So bringing this full-circle for Don's sake, I am not so sure you will do any better or worse in scoring with a NAPA battery over the Script reproduction battery but for some reason deep in my mind, I feel very certain you will at least have a script battery in there for Oshkosh!
