ajmac
I’ve just had my flatty running following a rebuild of everything. It idles great and revs very well but if I touch the throttle gently it will stall, must be over lean. If I hit the throttle to make the accel pump operate it revs up fine, probably too rich actually. It’s got an electric pump set to 3psi. Not that it matters but it’s a 1942 3.6 24 stud, lend lease from Detroit to England!
Does that sound like the float isn’t set correctly?
Video of it running and a light throttle stumble.
https://youtu.be/shsXxIbZP5Q
