Bruce ... ah the gaskets .. The gasket in the kit is round on the outside and triangle on the inside where it fits over the valve... will almost .. it does not fit over the valve , to small . I can screw it on the threads like a nut but will need to "forced " the rest of the way . I also guess that one of the "corners " of the triangle should be placed so the opening corresponds with the opening on the base ??? the old gasket fits
Sal , the only numbers that I see on any of them are on the [ correct ] one on the far right ..on top clockwise there are a ... F..... 8 ......5 .....4 ,
Tomo , thank you for the link , it will take several readings for me to understand but I have it printed out to take to the shop and learn it. The article says check the manufacture date .. where is it the only numbers are on the base 8BA 9515 there are none where the picture shows .
Tomorrow I will figure out the rest of the gaskets , put it together and reinstall and report back
I now have a greater appreciation for these muti-carb setups and you who build them , I thought jetting was the only concern I would have to learn .
Thanks to all for sticking with me on this....
Dan
Dan
