Ford 94 Carburator Issue?
You definitely need to figure out if it is a fuel or spark issue . . . then go from there.
Magneto: Just like checking with any other ignition . . . pull a wire from a plug and hold it a 1/4" away and crank it over - or just put a timing light on it. I run mags as often as possible - it is rare that they are intermittent . . . unless there is something funny going on with the ground/kill switch wiring or the switch itself. Or just put your tongue on the end of it and have your wife crank it over - you'll be screaming and she'll be laughing! :)
What type of mag? If it is an older mag like a Harman Collins, then it could have a bad coil in it. When the coil is weak, it will tend to quit once the ignition heats up. Once it cools down - works just fine again. If this is the case, then have Tom Cerello rebuild it and put a new coil in it.
What does it feel like when it quits? Like it is starving for fuel - and running out? If you take the air cleaners off and work the throttles (after it quits) - do you see any fuel coming out of the accell pump squirters?
Fuel Pumps: I tend to run the ones that have glass bowls on them - so I can see when they are pumping fuel (easily). One issue with the new/modern ones is that they usually have way too much pressure for Strombergs - so a pressure regulator is needed. Does your car currently have a pressure regulator on it? If so, maybe it is just set too low?
When it quits, pull the fuel line to the carbs - put the kill switch 'On' and see if you're getting good squirts of fuel when you just crank it over. I'd take a little can to capture the fuel in - and have a good fire extinguisher with yah! You need to determine if the pump is working . . . as it should at crank speed.
Feel free to ping me if you need more help.
B&S
B&S
All good advice, but we have to remember that some of us tend to be a little slow in the humor department! :eek:
I think it's fixed, thanks to all for the advice, I really appreciate it.
I tested the mag…full spark.
So it was a fuel issue.
Traced everything back from the carbs to the tank.
I guess I should have gone the other way. LOL
It appears to have been a clog in the valve in the bottom of the Model T tank that resides in the Boat Tail.
The valve was half blocked and this little bit of rubber seemed to be floating around and blocking it fully but only occasionally.
I was fairly sure that it was a fuel issue because I was starting to get a minor lean backfire.
Drained the tank, cleaned everything, seems to be OK.
I left the elec. fuel pump installed and on a switch.
Not sure if it's just my imagination, but it seems to run better with the elec. pump on.
We'll see!
Thanks again.
