Ford 3 window coupe door window felts
There are two, possibly three different window felt arrangements used 1935-36.
The earliest 1935's had some strange bottom glass channels and may have had a different felt system. Most 1935 and 1936 window felt arrangements are determined by the location of the inside door handle mount, those with the inside handle near the front used felt channel across the top of the window, those with the inside handle near center used single sided felt on the door and garnish molding all around the opening. The front handle style did not have a felt seal at the bottom of the door, relying on a flap on the glass channel setting rubber to seal when the window was closed. See my catalog at http://wescottsauto.com/DoorAndWindow/1935-36CoupeDoor.pdf (note, I am closing the resale business and will not be able to accept an order for these).
The ones I have been selling are from Vintique. They seem to be OK for the most part. CW Moss, All Ford Parts, and C&G should have them.
