Ford 1940 innerfender
I think in back it only bolts to the fender. There should be a bolt and rubber bumper near the brake line cut out. There may be early/late differences as well. Kube will have the correct answer.
Hello and thanks for answer... the problem i see now is that idont have any holes in the back, Do any have some pics?
Thanks
If the inner fender is a used one the portion of it with the bolt hole in it may have cracked and broken off.
Here's how the fender brace in the right rear fender looks. Click on photo to enlarge. I don't think the 1/4-20 nut, bolt and washers shown are stock 1940 OEM.
Here Is a picture of the inner fender brace for the front, this one is hand made but looks close and gives you an idea. Originals would have a bead rolled in the shape of an "X"
These go behind the front tire.
Hello and thanks for the help not many 40 in sweden ...
front innerfenders are not bolt to frame? only one bolt to the mudflap in the back?
The inner fender does bolt to the frame, it's bolted on with 4 bolts and one of the bolts is shared with the fender brace/mud flap. The mudflap is fastened to the fender with 2 bolts. Hope this helps.
