Ford 1933
Matej1991
Please can someone tell me why the 1933 Ford Victoria or Fordor Sedan are not as often for sale as the 1934 Ford? I saw only one Ford 1933 Fordor Sedan for sale in a year.
I wasn't around then but I've heard plenty of stories about front sheetmetal and grille swaps back in the day. Lots of 33s converted to 34s as well as 35s to 36s. People wanted to latest redesigned look.
1933 production---254,350
1934 production---776,879 about 3 times as many
If people were to change parts, they would not be able to change the wheelbase.
Whoa! First of all, the best selling body type in both model years was the Tudor sedan. Second of all, no definitive records exists as to the number of '33 models produced or as to the number of '34 models produced regardless of body type because Ford did not keep its records separating the two, unlike in all other pre-WWII model years. The figures cited above are calendar year production figures, not model year production figures. There were significantly more '34 models produced than those figures indicate for two simple reasons. First, 1933 model production did not start until well into January, 1933 and second, 1934 model production started in October, 1933.
I bought a Ford Model A Convertible Sedan of which less than 5000 were produced. But even those are more for sale than the 1933 Ford. I don't know if this information is correct but the 1933 Ford had 2 models. Model 18 and Model 40 so the search will be even more difficult.
Model 18 was the '32 model year designation. Those production figures are not mixed in with those for the Model(s) 40.
Mate191,
You're mixing apples and oranges. The United Kingdom only model 14 with its carryover '32 chassis with a wheelbase of 106" was produced in both 1933 and 1934. Its production figures are not mixed in with those of the Model(s) 40 (112" wheelbase) in the Ford production statistics.
No, Both the Model 14 and the Model 40 were sold side by side in 1933 and 1934 in the United Kingdom. The Model 14 was not sold outside of the United Kingdom. Its existence can be attributed to the draconian horsepower tax imposed there.
Both versions of the 1933 and 1934 Model 40s were sold worldwide during 1933 and 1934 and in some countries beyond the 1934 calendar year.
Model 40 and Model B because 1933 and 1934 also had 4 cylinders, was the wheelbase the same? And if the wheelbase is solved then why are there so few 1933 Fords for sale? Certainly more than 5,000 units of both the Victoria and the Fordor Sedan were produced.
525901
1933 and 1934 Ford Cowls compared. As has been mentioned, a lot of 1933 Fords have been changed to 1934 models. However, the Cowls are different between these two models. Check out this photo, and you will see that the indent for the rope anti-rattler stops way shorter on the 1934 model. That is not counting the tab on the 33 Ford and the hole on the 34 Ford for keeping the hood closed.
525901
Thank you sir. Can you please tell me if this difference in the cowl is on both sides or only on the passenger side as in the photo. Thank you.
Wheelbase is the same for 4 cyl and V8.
