Marshall V. Daut
I have fully or partially disassembled 14 Model A and T starters and generators with the intention of rebuilding them for my cars. I am NOT an electrically-minded or experienced person and have danced around addressing generator/starter issues for decades. But now I am going to man-up and face them head-on with these 14 generators and starters. No exchanges! And yes, I have the Model A starter/generator rebuild book. But it does not answer my question. I have looked on-line for an answer to what I consider a basic question - no success. Apparently my question is TOO basic to be addressed by the experts.
Here it is: If an armature passes a multimeter test and a growler test, does that mean it is up to snuff for re-use as-is and will perform its function correctly? In other words, is an armature either good or bad, no in-between? I realize that if the insulation is flaking off or burned, that is a different issue. That's an obvious problem. But I am concerned that my armatures test o.k. on the bench, but don't function satisfactorily in the car.
So, are there degrees of functionality hidden inside an armature, running from strong to weak that don't show up in bench testing, or is an armature either good or bad, nothing in-between?
'Sorry for the near-moronic question, you electrical gurus. But first things first.
Marshall
Marshall
