steve s
Great discussion! If I may be so bold to add my $0.02....All automotive gasolines in this country are manufactured under ASTM D 4814 specifications (www.astm.org) and, although each refinery is different, their product meets the same spec and is fungible (compatible with all the others). Vapor pressure, distillation and vapor lock protection are closely monitored by season and region and are regulated by U.S. EPA - not by oil companies and not by octane grade. Although many of us believe vapor pressure is the culprit in vapor lock problems, it is another value used in the industry called T20 V/L: The temperature at which the vapor to liquid ratio is 20:1 in the distillation curve. ... (Sorry for being so nerdy).
Old182,
Thanks for the clarifications and putting us on to the industry standards business. Surely no need to apologize to me for "being so nerdy"; I think of it as providing facts--which is good!
In case anyone is interested, there is a bible of-sorts regarding this stuff that you can see through Google Books. Here's the link:
http://books.google.com/books?id=J_...onepage&q=vapor lock standard T20 V/L&f=false
The vapor lock discussion is around page 78. Also, contains a lot more details about the butane and ethanol issues discussed earlier.
The standard involving the temperature at which the vapor/liquid ratio is 20 was apparently developed based on conditions under which diaphragm type fuel pumps for carbureted engines start having issues causing stalling or running rough. I was interested to see that they seem to define "vapor lock" as including running rough. I had assumed it meant engine "locked" or completely shut down. So, I guess I've had more true vapor lock issues than I realized after all.
Steve
