. . .No modern car has them. . .
I had to take out the foot rest on a RHD car.
Real uncomfortable and awkward.
I wonder what the reasoning is behind a rest anyway.
Did a 32 or later even have them?
I'm glad Jim mentioned that. I forgot to come back on last night to give my thoughts on the reason for the foot rest, but I believe in the days of dirt and gravel roads it might be real handy. I almost never use mine, but don't mind it being mounted where it is, and as Jim said, it comes in handy on rough roads.
I agree on this. It does help. But when I want to put the "Peddle to the metal(floor boards)", I take my foot off the rest because it is easer to get the gas peddle down enough to get the speed I want.
Maybe a stupid question, but have you played with the height of the rest? I think mine is about half way between throttle full up and down. I can say for sure that if you went for a ride with me you would see full use of the throttle.![]()
Marco, I think I have it screwed down as far at it will go until it hits the floor board. I'll have to check that. I may have an aftermarket rest that does not go down far enough. Could be also my long legs make it hard to bend my foot enough to get it full down. Thanks for the suggestion.
you could also install the front rubber matt ,and use the matt to locate the exacts spot. Draw a circle with a pencil ON YOUR NEW WOOD FLOOR then you will have the exact center spot for your foot rest.
