Ed in Maine
Thank you for you previous comments. I found the following:
1. Fan was loose on belt but because of the oil vapors etc., the fan does not get a good grip on the belt even when tightened. What things can be done to get a better belt to pulley grip. The pulley is a very smooth brass.
2. I found the the blade pitch was not enough. I searched on the internet and found information that the optimum blade angle is 27 degrees for an automotive fan. I did make this change.
3. I did run the car with a more advanced setting and I think you guys were right. It did seem to have more power.
The car did seem to be a bit cooler on a test drive but then again, I did not have any passengers. I would like to see it run cooler. Do your cars run below the boiling point if the car is left at an idle for an extended time? Mine will not. The next step will be to remove hoses and do a thorough flush job. It definitely would not be a good parade car. Thanks for all your help, Ed
