Most of you cast iron repair sleeves are either 3/32 or 1/8 wall. I think you said this is a 8BA block. If so it's 3-3/16 std. bore. If your bore is .080 over that's 3.268, SO, if I was going to sleeve that cyl I would use a 3-1/4 = 3.250 sleeve with a 3/32 wall. The repair sleeve is semi finish on the inside, about .025 smaller that the accuwall finish bore size, so after installing the sleeve you'll have to take out about .040 to make your .080 overbore. Any auto machine shop or auto parts store that has any help that knows anything can get any size repair sleeve. Walt
