Houdini
The short story is I'm having problem loosing coolant and found today that it's foaming and coming out the overflow. Found it was down about 1 gallon after about 15 miles driving. I'm using Prestone antifreeze with 50 percent distilled water.
The long story:
When I bought the car about 1 year ago, the previous owner used water only for about 18 years. I decided to use antifreeze and flushed and refilled the car with Prestone and distilled water. Found that my "level" was about at the baffle and didn't see any foam issues. The car seemed to run at 180 or less.
This Spring, I found the car running hotter in colder weather and then I had a water pump leak. So the net of all this is that I bought a new leakless water pump from Snyders and new hoses.
Before installing the new pump, I decided to flush the system. Reading an older thread on the barn, it was suggested to use Evapo-Rust as a good agent to get rid of rust without any acid or harmful effects. So I drained and added 3 gallons of the stuff and run it around the block a few times to heat it up slightly and left the stuff in the car for about a week. When I drained it out, it was pretty black, which is their indicator that it was spent. I then flushed the system several times. I disconnected the hoses and plug the bottoms and flushed the radiator and block separately. Eventually the water became clearer and clearer(less rust color). Next I installed the new water pump and hoses. Then filled with distilled water to check for leaks. No leaks, so I drained it one more time and refilled with distilled water. Then drove it about 15 miles to again check for leaks. I didn't check for foam so I don't know if it did or not. But it ran cooler again. Finally, I drained and filled with Prestone antifreeze and distilled water. Test drove and it stayed cool. After the drive I could not see the water level, so added water slowly till I could see it.
I thought it was just down a small amount and basically wanted to check to see how much it was down by adding water. But it took a gallon. Then I test drove and looked carefully for leaks. No water hose or pump leaks, but then I spotted the overflow leakiing water. At first I figured it was just normal as I filled it close to the top. But when I opened the cap right after I shut it down, it will full of foam.
So I'm wondering if there is still some residual Evapo-rust in the system causing foma when mixed with antifreeze, or does Prestone tend to do that. Since the new pump is probably pumping more efficiently than the old pump, could that be a contributor. This new pump has the cut down impeller.
Is there a different brand of antifreeze that either has antifoam in it, or is known not to foam. I can try refilling with just water, but I prefer to end up with some antifreeze and rust inhibitor eventually.
Are there any automotive anti foam products that can be used. I read where someone used rug doctor anti foam and said it worked. I also have the roofing nail in the overflow, which I put in just before I discovered the foaming problem.
PS: also did a flow test of the radiator and it emptied in about 3 seconds.
Frank
The long story:
Frank
