Foam in Anti-freeze
spinelll
What the heck is causing this foam?
I did the "Lestoil shuffle" a few years ago, but I don't think it's that.
Thanks
Leo
Drain the radiator and block and flush with water. Replace with 50/50 antifreeze and water that is meant for older cars, not the new stuff meant for newer cars and trucks.
Oil in water. What does your engine oil look like? How about your spark plugs?
If you have any water in your engines oil, your head gasket needs to be replaced.
Oil in coolant usually has the same cause.
Good luck.
Cavitation is where something moves through water fast enough to form a pocket of vapor. The vapor collapses as soon as the object passes or the water passes. I doubt that the water pump blades would move fast enough to cause cavitation. Most likely the water pump is mixing air into the coolant and there is something in the coolant that acts like a soap solution to support the air bubbles. It could be oil but it could be anything such as left over cleaning solution or bad coolant.
You can suck air in through worn seals on the water pump.
Years ago I had a foaming problem, rebuilt engine, clean inside, leakless pump, could drive forever in 90 degree heat, no overheating but foaming. Someone on THIS site mentioned to use Sierra antifreeze, so I tried it (50/50 mix) and it worked. No more foaming. Sierra is a few bucks more than some other brands but I was at a loss and ready to try anything. I'm certainly no chemist so I can't explain it.
Drain the coolant and save if antifreeze, flush with water, over fill with water, start engine and watch for bubbles. If you see bubbles than probably a head gasket, do a leak down test. If no bubbles it’s maybe the antifreeze, I wonder if a Gano filter in the upper hose would break up the bubbles?
Thanks for all of the suggestions. Trying to eliminate one-by-one.
As per some Fordbarn advice, the pic shows the four plugs and the anti-freeze I use.
Anything odd about the plugs?
I think this is the recommended anti-freeze for old cars.
On the head gasket, will a compression test reveal an issue?
Would I see white smoke out of the tail pipe?
Also, I had the car out a few days ago and had plenty of power.
Thanks
Leo
Driving at 45-50 mph noticed some coolant leaking past radiator cap. I knew I needed a new cap and ordered one. I checked the radiator level and it was fine. Started the engine and the coolant flowed with no issues. Manually increased the rpm to about 1500 or so and within seconds the flow of bubbles started and kept increasing until it became foam.
Ran compression test on warm engine with throttle wide open and got the following
1-70
2-60
3-64
4-69
By the way stock engine. Will be pulling head tomorrow as it appears to me to be a blown head gasket.
If it is a head gasket will probably replace the head with a 5.5 that I have. I already had replaced all the studs and nuts with new and harder studs about 2 years ago when I last blew a gasket. Should the head bolt torque still be at 55ftlbs with the Snyder 5.5?
Thanks, you all are great
Thoroughly clean the head and block. Final clean with acetone. Fill any nicks or divots with JB Weld and sand flat with some wet and dry sandpaper wrapped around a flat file. Use the Best brand graphite head gasket and the copper spray gasket cement. Do not use the gasket on the goose neck, just some gasket sealer.
Toque to 55 foot-pounds in 10 foot-pound increments. Warm engine then let it cool completely and re-torque. Then re-torque on cool engine after 50 to 100 miles. Repeat after 500 miles and then every year. Use some anti seize on the studs and nuts. Make sure the threaded holes in the block are clean to the bottom.
You may already know all this but newbe's read the forum so that this may be helpful for them. Even though this information has been published before, it may be hard to search for.
Forgot to mention to check the fit of the head to the block. Put some plastigauge at various places and bolt the head on without a gasket. There should be no more than 0.002 gap anywhere.
Thanks
Leo
Plugs look good to me. Compression test might or might not show if you have a problem. You don’t need white smoke to have a problem.
I can’t tell you the number of head gaskets I have replaced in the last 60 years.
I would drain all the coolant. Really Flush the radiator and add just water. Drive the car and see what happens. I don’t think the water pump has anything to do with foaming. As in the Model T, a good percentage of the cooling in a Model A is natural movement, hot up and out, cold down and in. 30 plus gallons per minute if I remember correctly.
Good luck.
Years ago I found that one particular brand of anti-freeze foamed and another one didn't. You might want to try a different brand.
Charlie Stephens
